Network path not found
A Network path not found message during VM deployment on an SMB share typically indicates a DNS issue in which the host does not yet have a record on the DNS server. Resolve this issue by updating the DNS record or the host file.
Message
Network path not found -
This message reflects a DNS issue and occurs during VM deployment on an SMB share when the host does not have a record on the DNS server.
Typically, the domain DNS server should automatically update the host record within 24 to 48 hours when a new host is configured in the domain. However, this update does not always automatically happen.
Corrective action
If you are a domain administrator, manually update the DNS host record.
If you are not a domain administrator, update the host file (
C:\Windows\System32\drivers\etc\hosts).The host file does not have a file extension (
.txt).
