No response from the server
NetApp SMI-S Provider might not respond to a query when no storage system has been added to the CIMOM repository. Verify whether a storage system is registered and add one if needed.
Issue
The server does not respond when queried.
Cause
This issue occurs when there is no storage system added to the CIMOM repository.
Corrective action
Enter the following command to verify that a storage system is added:
smis listIf there is no storage system listed, add a storage system by entering the following command:
smis add storage_sys storage_sys_user storage_sys_pwd
