NetApp SMI-S Provider
Nondefault firewalls must have ports manually added as exceptions
If you use a firewall other than the default Windows firewall, NetApp SMI-S Provider might be unable to communicate with clients or send indications unless the required ports are added as exceptions. Add these ports to your firewall configuration to resolve the issue.
  • Issue
    If you are using a firewall other than the default Windows firewall, you might experience the following issues:
    • SMI-S Provider is unable to communicate with a removed SMI-S client.
    • The SMI-S client is unable to receive indications from SMI-S Provider.
  • Cause
    This issue occurs when you use a firewall other than the default Windows firewall without first manually adding the necessary ports as exceptions.
  • Corrective action
    Add ports 427, 5988, and 5989 as exceptions to your firewall.
