Possible errors while loading shared libraries
Messages
Error while loading shared libraries: libssl.so 1.0.0: cannot open shared object file: No such file or directory.The
smis cimserverstatus shows the cimserver is running properly, but all other/usr/netapp/smis/pegasus/bin/cimcommands show various failure messages.For example, you might receive the message
cimserver not runningwhen executing thecimserver, or you might receive the message/usr/netapp/smis/pegasus/bin/ cimcli: symbol lookup error: /usr/netapp/smis/pegasus/bin/cimcli: undefined symbol: _ZN7Pegasus16StringConversion21decimalStringToUint64EPKcRywhen executing cimcli. These examples are not all-inclusive. -
This message (and similar messages) occur when the
LD_LIBRARY_PATHenvironment is not set to the installation directory. -
Corrective action
Enter one of the following commands to set the
LD_LIBRARY_PATHenvironment variable to the installation directory:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/netapp/smis/pegasus/lib
setenv LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/netapp/smis/pegasus/lib
