SCVMM rescan operation failed to locate or communicate with SMI-S Provider
In rare instances, System Center Virtual Machine Manager (SCVMM) cannot locate or communicate with NetApp SMI-S Provider after a security infrastructure update. Resolve this issue by reinstalling the provider and running the rescan operation in SCVMM.
Issue
In rare instances, SCVMM is not able to locate SMI-S Provider.
Cause
This issue can occur if the security infrastructure is updated with new GPOs. When they take effect after the reboot of SMI-S Provider host, SCVMM host might not trust the SMI-S Provider or the host.
Corrective action
Uninstall SMI-S Provider and install it again.
Run the rescan operation in SCVMM for the SMI-S Provider.
