smis class
The smis class command lists information about a specified class or all classes.
Syntax
smis class
name_space {niall | {ei | ni | gi | gc} class_name}} [-t {http | https}]
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
A user with a valid user name and password
name_spaceName space supported by the CIMOM
niall
Enumerate all instance names
ei
Enumerate instances for a class
ni
Enumerate instance names for a class
gi
Get instances for a class
gc
Get class for a class name
class_nameName of the class for which you want information
[-t {http | https}]Protocol to be used: HTTPS (default) or HTTP
Example
The smis class command and its abbreviated output:
smis class root/ontap gi CIM_StorageVolume 1: ONTAP_StorageVolume.CreationClassName="ONTAP_StorageVolume",DeviceID="P3LfGJdC-mN5",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" 2: ONTAP_StorageVolume.CreationClassName="ONTAP_StorageVolume",DeviceID="P3LfGJcmzpHt",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" 3: ONTAP_StorageVolume.CreationClassName="ONTAP_StorageVolume",DeviceID="P3LfGJc30t26",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" 4: ONTAP_StorageVolume.CreationClassName="ONTAP_StorageVolume",DeviceID="P3LfGJcSgbiT",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815" 5: ONTAP_StorageVolume.CreationClassName="ONTAP_StorageVolume",DeviceID="P3LfGJcSgrA9",SystemCreationClassName="ONTAP_StorageSystem",SystemName="ONTAP:0135027815"
