Enable indications in SMI-S Provider
Alert, FileSystem Quota, and Lifecycle indications are disabled by default. You can enable these indications by setting the environment variable PEGASUS_DISABLE_INDICATIONS to false.
Before you begin
You must already have login credentials as Administrator.
You must already have logged in to the host system as Administrator.
About this task
When PEGASUS_DISABLE_INDICATIONS is set to false, then Alert (ONTAP_AlertIndication), FileSystem Quota (ONTAP_FSQuotaIndication), and Lifecycle indications are enabled on NetApp SMI-S Provider.
Steps
Access NetApp SMI-S Provider.
Set the
PEGASUS_DISABLE_INDICATIONSenvironment variable tofalse. -
Restart the CIM server:
smis cimserver restart
