Specifying trace settings
Having tracing enabled is important for gathering information for troubleshooting. However, having tracing enabled can impact performance, so carefully consider what must be traced and how long you need tracing enabled.
Before you begin
You must already have login credentials as Administrator.
You must already have logged in to the host system as Administrator.
Steps
Access NetApp SMI-S Provider.
Specify various trace settings as applicable:
Action Command Specify the components to be traced
cimconfig -s traceComponents=components -pSpecify the trace facility
cimconfig -s traceFacility=facility -pSpecify the location of the trace file
cimconfig -s traceFilePath=path_name -pSpecify the trace level
cimconfig -s traceLevel=level -p -
Restart the CIM server:
smis cimserver restart
