Verify that the storage system is working correctly
Before SMI-S Provider can be configured, you must add at least one storage system to the CIMOM repository, and then verify that the storage system is working correctly.
You must already have logged in as Administrator.
You must already have accessed SMI-S Provider.
Add at least one storage system to the CIMOM repository:
To add a storage system with an… Enter this command… HTTP connection between the provider and the storage system
smis add storage_sys storage_sys_userHTTPS connection between the provider and the storage system
smis addsecure storage_sys storage_sys_userThe command waits for up to 15 minutes for the provider to update the cache and respond.
Verify the output for the following commands:
For this command… Verify that… smis listThe number of items matches the number of storage systems being managed.
smis disksThe number of disks matches the total number of disks on all storage systems.
smis lunsThe number of LUNs matches the total number of LUNs on all storage systems.
smis poolsThe number of ONTAP_ConcretePools matches the total number of aggregates on all storage systems.
smis volumesThe number of volumes matches the total number of volumes on all storage systems.
