Snap Creator Agent
The Snap Creator Agent is typically installed on the same host where an application or database is installed. The Agent is where the plug-ins are located. The Agent is sometimes shortened to scAgent within Snap Creator.
The Agent accepts application quiesce and unquiesce commands, as well as other PRE/POST commands, from the Snap Creator Server. The Snap Creator Agent is required when using plug-ins.
