Snap Creator Framework
CLI commands for creating SVM roles
Contributors netapp-aherbin NetAppZacharyWambold
The following table lists the commands that are required to create a role for a new SVM user.
Command directory name Command to be run
adduser
role create -role VSERVERRBACROLE_New -cmddirname "adduser" -vserver Snapcreator
event generate-autosupport-log
role create -role VSERVERRBACROLE_New -cmddirname "event generate-autosupport-log" -vserver Snapcreator
lun comment
role create -role VSERVERRBACROLE_New -cmddirname "lun comment" -vserver Snapcreator
lun create
role create -role VSERVERRBACROLE_New -cmddirname "lun create" -vserver Snapcreator
lun delete
role create -role VSERVERRBACROLE_New -cmddirname "lun delete" -vserver Snapcreator
lun geometry
role create -role VSERVERRBACROLE_New -cmddirname "lun geometry" -vserver Snapcreator
lun igroup add
role create -role VSERVERRBACROLE_New -cmddirname "lun igroup add" -vserver Snapcreator
lun igroup create
role create -role VSERVERRBACROLE_New -cmddirname "lun igroup create" -vserver Snapcreator
lun igroup set
role create -role VSERVERRBACROLE_New -cmddirname "lun igroup set" -vserver Snapcreator
lun igroup show
role create -role VSERVERRBACROLE_New -cmddirname "lun igroup show" -vserver Snapcreator
lun map
role create -role VSERVERRBACROLE_New -cmddirname "lun map" -vserver Snapcreator
lun mapping show
role create -role VSERVERRBACROLE_New -cmddirname "lun mapping show" -vserver Snapcreator
lun modify
role create -role VSERVERRBACROLE_New -cmddirname "lun modify" -vserver Snapcreator
lun move
role create -role VSERVERRBACROLE_New -cmddirname "lun move" -vserver Snapcreator
lun offline
role create -role VSERVERRBACROLE_New -cmddirname "lun offline" -vserver Snapcreator
lun online
role create -role VSERVERRBACROLE_New -cmddirname "lun online" -vserver Snapcreator
lun resize
role create -role VSERVERRBACROLE_New -cmddirname "lun resize"-vserver Snapcreator
lun show
role create -role VSERVERRBACROLE_New -cmddirname "lun show" -vserver Snapcreator
lun unmap
role create -role VSERVERRBACROLE_New -cmddirname "lun unmap" -vserver Snapcreator
network
role create -role VSERVERRBACROLE_New -cmddirname "network" -vserver SnapCreator
network connections
role create -role VSERVERRBACROLE_New -cmddirname "network connections" -vserver SnapCreator
network connections active
role create -role VSERVERRBACROLE_New -cmddirname "network connections active" -vserver SnapCreator
network connections listening show
role create -role VSERVERRBACROLE_New -cmddirname "network connections listening show" -vserver SnapCreator
network interface
role create -role VSERVERRBACROLE_New -cmddirname "network interface" -vserver SnapCreator
network routing-groups
role create -role VSERVERRBACROLE_New -cmddirname "network routing-groups" -vserver SnapCreator
restore-file
role create -role VSERVERRBACROLE_New -cmddirname "restore-file" -vserver Snapcreator
snapmirror
role create -role VSERVERRBACROLE_New -cmddirname "snapmirror" -vserver SnapCreator
version
role create -role VSERVERRBACROLE_New -cmddirname "version" -vserver Snapcreator
volume
role create -role VSERVERRBACROLE_New -cmddirname "volume"
volume autosize
role create -role VSERVERRBACROLE_New -cmddirname "volume autosize" -vserver Snapcreator
volume clone
role create -role VSERVERRBACROLE_New -cmddirname "volume clone" -vserver Snapcreator
volume clone create
role create -role VSERVERRBACROLE_New -cmddirname "volume clone create" -vserver Snapcreator
volume create
role create -role VSERVERRBACROLE_New -cmddirname "volume create" -vserver Snapcreator
volume destroy
role create -role VSERVERRBACROLE_New -cmddirname "volume destroy" -vserver Snapcreator
volume efficiency off
role create -role VSERVERRBACROLE_New -cmddirname "volume efficiency off" -vserver Snapcreator
volume efficiency on
role create -role VSERVERRBACROLE_New -cmddirname "volume efficiency on" -vserver Snapcreator
volume efficiency start
role create -role VSERVERRBACROLE_New -cmddirname "volume efficiency start" -vserver Snapcreator
volume efficiency show
role create -role VSERVERRBACROLE_New -cmddirname "volume efficiency show" -vserver Snapcreator
volume file
role create -role VSERVERRBACROLE_New -cmddirname "volume file" -vserver Snapcreator
volume file clone
role create -role VSERVERRBACROLE_New -cmddirname "volume file clone" -vserver Snapcreator
volume file clone create
role create -role VSERVERRBACROLE_New -cmddirname "volume file clone create" -vserver Snapcreator
volume modify
role create -role VSERVERRBACROLE_New -cmddirname "volume modify" -vserver Snapcreator
volume mount
role create -role VSERVERRBACROLE_New -cmddirname "volume mount" -vserver Snapcreator
volume offline
role create -role VSERVERRBACROLE_New -cmddirname "volume offline" -vserver Snapcreator
volume show
role create -role VSERVERRBACROLE_New -cmddirname "volume show" -vserver Snapcreator
volume size
role create -role VSERVERRBACROLE_New -cmddirname "volume size" -vserver Snapcreator
volume snapshot create
role create -role VSERVERRBACROLE_New -cmddirname "volume snapshot create" -vserver Snapcreator
volume snapshot delete
role create -role VSERVERRBACROLE_New -cmddirname "volume snapshot delete" -vserver Snapcreator
volume snapshot restore
role create -role VSERVERRBACROLE_New -cmddirname "volume snapshot restore" -vserver Snapcreator
volume unmount
role create -role VSERVERRBACROLE_New -cmddirname "volume unmount" -vserver Snapcreator
vserver export-policy rule show
role create -role VSERVERRBACROLE_New -cmddirname "vserver export-policy rule show" -vserver Snapcreator
vserver export-policy show
role create -role VSERVERRBACROLE_New -cmddirname "vserver export-policy show" -vserver Snapcreator
vserver fcp
role create -role VSERVERRBACROLE_New -cmddirname "vserver fcp" -vserver Snapcreator
vserver fcp initiator show
role create -role VSERVERRBACROLE_New -cmddirname "vserver fcp initiator show" -vserver Snapcreator
vserver fcp show
role create -role VSERVERRBACROLE_New -cmddirname "vserver fcp show" -vserver Snapcreator
vserver fcp status
role create -role VSERVERRBACROLE_New -cmddirname "vserver fcp status" -vserver Snapcreator
vserver iscsi
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi" -vserver Snapcreator
vserver iscsi connection show
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi connection show" -vserver Snapcreator
vserver iscsi interface accesslist add
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi interface accesslist add" -vserver Snapcreator
vserver iscsi interface accesslist show
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi interface accesslist show" -vserver Snapcreator
vserver iscsi isns query
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi isns query" -vserver Snapcreator
vserver iscsi nodename
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi nodename" -vserver Snapcreator
vserver iscsi session show
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi session show" -vserver Snapcreator
vserver iscsi show
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi show" -vserver Snapcreator
vserver iscsi status
role create -role VSERVERRBACROLE_New -cmddirname "vserver iscsi status" -vserver Snapcreator
vserver nfs
role create -role VSERVERRBACROLE_New -cmddirname "vserver nfs" -vserver Snapcreator
vserver nfs status
role create -role VSERVERRBACROLE_New -cmddirname "vserver nfs status" -vserver Snapcreator
vserver services dns hosts show
role create -role VSERVERRBACROLE_New -cmddirname "vserver services name-service dns hosts show" -vserver SnapCreator
vserver services unix-group create
role create -role VSERVERRBACROLE_New -cmddirname "vserver services name-service unix-group create" -vserver Snapcreator
vserver services unix-group show
role create -role VSERVERRBACROLE_New -cmddirname "vserver services name-service unix-group show" -vserver Snapcreator
vserver services unix-user create
role create -role VSERVERRBACROLE_New -cmddirname "vserver services name-service unix-user create" -vserver Snapcreator
vserver services unix-user show
role create -role VSERVERRBACROLE_New -cmddirname "vserver services name-service unix-user show" -vserver Snapcreator
