SAP HANA plug-in parameters
The following table lists the SAP HANA plug-in parameters, provides the parameter settings, and describes the parameters.
| Parameter | Setting | Description |
HANA_SID |
Example: ABC |
HANA database SID. |
HANA_NODES |
Example: node1, node2, node3 |
Comma-separated list of HANA nodes on which the hdbsql statements can be executed. |
HANA_USER_NAME |
Example: backupUser |
HANA database user name. The minimum privilege required for this user is BACKUP ADMIN privilege. |
HANA_PASSWORD |
Example: hfasfh87r83r |
HANA database password. |
HANA_INSTANCE |
Example: 42 |
HANA node instance number. |
HANA_HDBSQL_CMD |
Example: /usr/sa p/hdbclient/ hdbsql |
Path to the HANA hdbsql command. If this parameter is not set, hdbsql on the search path is used. The default is hdbsql. |
HANA_OSDB_USER |
Example: user1 |
The operating system user for executing hdbsql (usually sidadm) must have the hdbsql binary in the search path and the permission to execute it. |
HANA_USERSTORE_KEYS |
Example: node1:key1, node 2:key2, node3:ke y3 |
Comma-separated list of HANA userstore keys and node pairs using which the hdbsql statements can be executed. |
HANA_FILE_BACKUP_ENABLE |
“Y” or “N” |
Determines whether Snap Creator should enable file-based backup for the SAP HANA plug-in. This setting is useful when you want to perform the SAP HANA file-based backup operation. |
HANA_FILE_BACKUP_PATH |
Example:/hana/data/SCN/mnt00001 |
(Optional) Path to the directory where database file backup can be stored. If this parameter is not set, use default. |
HANA_FILE_BACKUP_PREFIX |
Example: SnapCreator_<HANA_FILE_BACKUP_PREFIX>__<CURRENT_TIMESTAMP> |
(Optional) Adds a prefix to the backup file name. Default: SnapCreator__<CURRENT_TIMESTAMP> |
HANA_INTEGRITY_CHECK_ENABLE |
“Y” or “N” |
Determines whether Snap Creator should enable Integrity Check for the SAP HANA plug-in. This setting is usual when you want to perform the SAP HANA Integrity Check operation. |
HANA_TEMP_FILE_BACKUP_PATH |
Example:/temp |
(Optional) Path where the temporary database file for Integrity Check can be stored. If not sure, use default. |
HANA_LOG_CLEANUP_ENABLE |
“Y” or “N” |
Enables Log Catalog cleanup. |
