SnapCenter Software 4.5
SnapCenter Custom Plug-ins features
Contributors netapp-soumikd netapp-asubhas
SnapCenter integrates with the plug-in application and with NetApp technologies on the storage system. To work with Custom Plug-ins, you use the SnapCenter graphical user interface.
  • Unified graphical user interface
    The SnapCenter interface provides standardization and consistency across plug-ins and environments. The SnapCenter interface enables you to complete consistent backup, restore, recovery, and clone operations across plug-ins, use centralized reporting, use at-a-glance dashboard views, set up role-based access control (RBAC), and monitor jobs across all plug-ins.
  • Automated central administration
    You can schedule backup operations, configure policy-based backup retention, and perform restore operations. You can also proactively monitor your environment by configuring SnapCenter to send email alerts.
  • Nondisruptive NetApp Snapshot copy technology
    SnapCenter uses NetApp Snapshot copy technology with the SnapCenter Custom Plug-ins to back up resources. Snapshot copies consume minimal storage space.
Using the Custom Plug-ins feature also offers the following benefits:
  • Support for backup, restore, and clone workflows
  • RBAC-supported security and centralized role delegation
    You can also set the credentials so that the authorized SnapCenter users have application-level permissions.
  • Creation of space-efficient and point-in-time copies of resources for testing or data extraction by using NetApp FlexClone technology
    A FlexClone license is required on the storage system where you want to create the clone.
  • Support for the consistency group (CG) Snapshot copy feature of ONTAP as part of creating backups.
  • Capability to run multiple backups simultaneously across multiple resource hosts
    In a single operation, Snapshot copies are consolidated when resources in a single host share the same volume.
  • Capability to create Snapshot copy using external commands.
  • Capability to create file system consistent Snapshot copies in Windows environments.
