SnapCenter Software 4.7
Back up resources using PowerShell cmdlets
Contributors netapp-soumikd
You can use the PowerShell cmdlets to backup SQL Server databases or Windows file systems. This would include backing up a SQL Server database or Windows file system includes establishing a connection with the SnapCenter Server, discovering the SQL Server database instances or Windows file systems, adding a policy, creating a backup resource group, backing up, and verifying the backup.
What you will need
  • You must have prepared the PowerShell environment to execute the PowerShell cmdlets.
  • You must have added the storage system connection and created a credential.
  • You must have added hosts and discovered resources.
Steps
  1. Initiate a connection session with the SnapCenter Server for a specified user by using the Open-SmConnection cmdlet.
    Open-smconnection  -SMSbaseurl  https://snapctr.demo.netapp.com:8146
    The username and password prompt is displayed.
  2. Create a backup policy by using the Add-SmPolicy cmdlet.
    This example creates a new backup policy with a SQL backup type of FullBackup:
    PS C:\> Add-SmPolicy -PolicyName TESTPolicy
    -PluginPolicyType SCSQL -PolicyType Backup
    -SqlBackupType FullBackup -Verbose
    This example creates a new backup policy with a Windows file system backup type of CrashConsistent:
    PS C:\> Add-SmPolicy -PolicyName FileSystemBackupPolicy
    -PluginPolicyType SCW -PolicyType Backup
    -ScwBackupType CrashConsistent -Verbose
  3. Discover host resources by using the Get-SmResources cmdlet.
    This example discovers the resources for the Microsoft SQL plug-in on the specified host:
    C:\PS>PS C:\> Get-SmResources -HostName vise-f6.sddev.mycompany.com
    -PluginCode SCSQL
    This example discovers the resources for Windows file systems on the specified host:
    C:\PS>PS C:\> Get-SmResources -HostName vise2-f6.sddev.mycompany.com
    -PluginCode SCW
  4. Add a new resource group to SnapCenter by using the Add-SmResourceGroup cmdlet.
    This example creates a new SQL database backup resource group with the specified policy and resources:
    PS C:\> Add-SmResourceGroup -ResourceGroupName AccountingResource
    -Resources @{"Host"="visef6.org.com";
    "Type"="SQL Database";"Names"="vise-f6\PayrollDatabase"}
    -Policies "BackupPolicy"
    This example creates a new Windows file system backup resource group with the specified policy and resources:
    PS C:\> Add-SmResourceGroup -ResourceGroupName EngineeringResource
    -PluginCode SCW -Resources @{"Host"="WIN-VOK20IKID5I";
    "Type"="Windows Filesystem";"Names"="E:\"}
    -Policies "EngineeringBackupPolicy"
  5. Initiate a new backup job by using the New-SmBackup cmdlet.
    PS C:> New-SmBackup -ResourceGroupName PayrollDataset -Policy FinancePolicy
  6. View the status of the backup job by using the Get-SmBackupReport cmdlet.
    This example displays a job summary report of all jobs that were run on the specified date:
    PS C:\> Get-SmJobSummaryReport -Date '1/27/2016'
The information regarding the parameters that can be used with the cmdlet and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Cmdlet Reference Guide.
