Storage types supported by SnapCenter Custom Plug-ins
SnapCenter supports a wide range of storage types on both physical and virtual machines. You must verify the support for your storage type before installing SnapCenter Custom Plug-ins.
| Machine | Storage type |
Physical and NFS direct mounts on the VM hosts (VMDKs and RDM LUNs are not supported.) |
FC-connected LUNs |
iSCSI-connected LUNs |
NFS-connected volumes |
