SnapCenter Software 5.0
Manage policies
You can detach policies from a resource or resource group, modify, delete, view, and copy.
Modify policies
You can modify the replication options, Snapshot retention settings, error retry count, or scripts information while a policy is attached to a resource or resource group. You can modify the schedule type (frequency) only after you detach a policy.
About this task
Modifying the schedule type in a policy requires additional steps because the SnapCenter Server registers the schedule type only at the time the policy is attached to a resource or resource group.
If you want to…​ Then…​
Add an additional schedule type
Create a new policy and attach it to the necessary resources or resource groups.
For example, if a resource group policy specifies only hourly backups and you want to add daily backups also, you can create a policy with a daily schedule type and add it to the resource group. The resource group would then have two policies: hourly and daily.
Remove or change a schedule type
Perform the following:
  1. Detach the policy from every resource and resource group that uses that policy.
  2. Modify the schedule type.
  3. Attach the policy again to all the resources and resource groups.
For example, if a policy specifies hourly backups and you want to change that to daily backups, you must detach the policy first.
Steps
  1. In the left navigation pane, click Settings.
  2. In the Settings page, click Policies.
  3. Select the policy, and then click Modify.
  4. Modify the information, and then click Finish.
Detach policies
You can detach policies from a resource or resource group any time that you no longer want those policies to govern data protection for the resources. You must detach a policy before you can delete it or before you modify the schedule type.
Steps
  1. In the left navigation pane, click Resources, and then select the appropriate plug-in from the list.
  2. In the Resources page, select Resource Group from the View list.
  3. Select the resource group, and then click Modify Resource Group.
  4. In the Policies page of the Modify Resource Group wizard, from the drop-down list, clear the check mark next to the policies you want to detach.
  5. Make any additional modifications to the resource group in the rest of the wizard, and then click Finish.
Delete policies
If you no longer require policies, you might want to delete them.
Before you begin
You should detach the policy from resource or resource groups if the policy is associated with any resource or resource groups.
Steps
  3. Select the policy, and then click Delete.
  4. Click Yes.
