NATIVE style
SnapCenter supports non-PERL programming or scripting languages to create plug-ins. This is known as NATIVE style programming, which can be script or BATCH file.
The NATIVE-style plug-ins must follow certain conventions given below:
The plug-in must be executable
For Unix systems, the user who runs the agent must have execute privileges on the plug-in
For Windows systems, PowerShell plug-ins must have the suffix .ps1, other windows scripts must have either .cmd or .bat suffix and must be executable by the user
The plug-ins must react to command-line argument like "-quiesce", "-unquiesce"
The plug-ins must return exit code 99 incase an operation or function is not implemented
The plug-ins must use a specific syntax to pass results back to the server
General plug-in handling
Logging error messages
Each operation can send messages back to the server, which displays and stores the content. A message contains the message level, a timestamp, and a message text. Multiline messages are supported.
Format:
SC_MSG#<level>#<timestamp>#<message> SC_MESSAGE#<level>#<timestamp>#<message>
Using plug-in stubs
SnapCenter plug-ins must implement plug-in stubs. These are methods that the SnapCenter Server calls based on a specific workflow.
| Plug-in Stub | Optional/Required | Purpose |
quiesce |
required |
This stub is responsible for performing a quiesce. It places the application into a state where we can create a Snapshot. This is called before storage Snapshot operation. |
unquiesce |
required |
This stub is responsible for performing a unquiesce. It places the application in a normal state. This is called after storage Snapshot operation. |
clone_pre |
optional |
This stub is responsible for performing pre clone tasks. This assumes that you are using the built-in SnapCenter cloning interface and also is only triggered while performing action "clone_vol or clone_lun". |
clone_post |
Optional |
This stub is responsible for performing post clone tasks. This assumes you are using the built-in SnapCenter cloning interface and also is only triggered while performing "clone_vol or clone_lun" operations. |
restore_pre |
Optional |
This stub is responsible for performing pre restore tasks. This assumes you are using the built-in SnapCenter restore interface and is only triggered while performing restore operation. |
restore |
optional |
This stub is responsible for performing all restore actions. This assumes you are not using built-in restore interface. It is triggered while performing restore operation. |
Windows PowerShell
Check if the script can be executed on your system. If you cannot execute the script, set Set-ExecutionPolicy bypass for the script and retry the operation.
if ($args.length -ne 1) {
write-warning "You must specify a method";
break;
function log ($level, $message) {
$d = get-date
echo "SC_MSG#$level#$d#$message"
function quiesce {
$app_name = (get-item env:APP_NAME).value
log "INFO" "Quiescing application using script $app_name";
log "INFO" "Quiescing application finished successfully"
function unquiesce {
log "INFO" "Unquiescing application using script $app_name";
log "INFO" "Unquiescing application finished successfully"
switch ($args[0]) {
"-quiesce" {
quiesce;
"-unquiesce" {
unquiesce;
default {
write-error "Function $args[0] is not implemented";
exit 99;
exit 0;
