Restore custom plug-in resources
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Creating your file...
Your file is ready
The restore and recovery workflow includes planning, performing the restore operations, and monitoring the operations.
About this task
The following workflow shows the sequence in which you must perform the restore operation:
![Restore workflow](../media/restore_workflow.gif)
You can also use PowerShell cmdlets manually or in scripts to perform backup, restore, and clone operations. For information about PowerShell cmdlets, use the SnapCenter cmdlet help or see the SnapCenter Software Cmdlet Reference Guide.
