SnapCenter Software 5.0
Monitor SnapCenter plug-in package installation status
You can monitor the progress of SnapCenter plug-in package installation by using the Jobs page. You might want to check the progress of installation to determine when it is complete or if there is an issue.
About this task
The following icons appear on the Jobs page and indicate the state of the operation:
  • In progress icon In progress
  • Completed icon Completed successfully
  • Failed icon Failed
  • Completed with warnings icon Completed with warnings or could not start due to warnings
  • Verification job is queued Queued
Steps
  1. In the left navigation pane, click Monitor.
  2. In the Monitor page, click Jobs.
  3. In the Jobs page, to filter the list so that only plug-in installation operations are listed, do the following:
    1. Click Filter.
    2. Optional: Specify the start and end date.
    3. From the Type drop-down menu, select Plug-in installation.
    4. From the Status drop-down menu, select the installation status.
    5. Click Apply.
  4. Select the installation job and click Details to view the job details.
  5. In the Job Details page, click View logs.
