SnapCenter Software 5.0
Define a clone strategy for Oracle databases
Defining a strategy before cloning your database ensures that the cloning operation is successful.
Types of backups supported for cloning
SnapCenter supports cloning of different types of backups of Oracle databases.
  • Online data backup
  • Online full backup
  • Offline mount backup
  • Offline shutdown backup
  • Backups of Data Guard standby databases and Active Data Guard standby databases
  • Online data backups, online full backups, offline mount backups, and offline shutdown backups in a Real Application Clusters (RAC) configuration
  • Online data backups, online full backups, offline mount backups, and offline shutdown backups in an Automatic Storage Management (ASM) configuration
    Important SAN configurations are not supported if user_friendly_names option in the multipath configuration file is set to yes.
Note Cloning of archive log backups is not supported.
Types of cloning supported for Oracle databases
In an Oracle database environment, SnapCenter supports cloning of a database backup. You can clone the backup from primary and secondary storage systems.
The SnapCenter Server uses NetApp FlexClone technology to clone backups.
You can refresh a clone by running the "Refresh-SmClone" command. This command creates a backup of the database, deletes the existing clone, and creates a clone with the same name.
Note The clone refresh operation can only be performed using the UNIX commands.
Clone naming conventions for Oracle databases
From SnapCenter 3.0, the naming convention used for clones of file systems is different from the clones of ASM disk groups.
  • The naming convention for SAN or NFS file systems is FileSystemNameofsourcedatabase_CLONESID.
  • The naming convention for ASM disk groups is SC_HASHCODEofDISKGROUP_CLONESID.
    HASHCODEofDISKGROUP is an automatically generated number (2 to 10 digits) that is unique for each ASM disk group.
Limitations of cloning Oracle databases
You should be aware of the limitations of clone operations before you clone the databases.
  • If you are using any version of Oracle from 11.2.0.4 to 12.1.0.1, the clone operation will be in hung state when you run the renamedg command. You can apply the Oracle patch 19544733 to fix this issue.
  • Cloning of databases from a LUN that is directly attached to a host (for instance, by using Microsoft iSCSI Initiator on a Windows host) to a VMDK or an RDM LUN on the same Windows host, or another Windows host, or vice versa, is not supported.
  • The root directory of the volume mount point cannot be a shared directory.
  • If you move a LUN that contains a clone to a new volume, the clone cannot be deleted.
