Define a restore and recovery strategy for IBM Db2 resources
You must define a strategy before you restore and recover your database so that you can perform restore and recovery operations successfully.
Only manual recovery of database is supported. |
Steps
Determine the restore strategies supported for manually added IBM Db2 resources
Determine the restore strategies supported for auto discovered IBM Db2 databases
