Type of restore strategy supported for automatically discovered IBM Db2
You must define a strategy before you can successfully perform restore operations using SnapCenter.
Complete resource restore is the restore strategy supported for automatically discovered IBM Db2 databases. This restores all the volumes, qtrees, and LUNs of a resource.
