Define a restore and recovery strategy for PostgreSQL resources
You must define a strategy before you restore and recover your cluster so that you can perform restore and recovery operations successfully.
Only manual recovery of cluster is supported. |
Steps
Determine the restore strategies supported for manually added PostgreSQL resources
Determine the restore strategies supported for auto discovered PostgreSQL clusters
Decide the type of recovery operations that you want to perform.
