Type of restore strategy supported for automatically discovered PostgreSQL
You must define a strategy before you can successfully perform restore operations using SnapCenter.
Complete resource restore is the restore strategy supported for automatically discovered PostgreSQL clusters. This restores all the volumes, qtrees, and LUNs of a resource.
