Monitor Unix file systems clone operations
You can monitor the progress of SnapCenter clone operations by using the Jobs page. You might want to check the progress of an operation to determine when it is complete or if there is an issue.
The following icons appear on the Jobs page, and indicate the state of the operation:
In progress -
Completed successfully -
Failed -
Completed with warnings or could not start due to warnings -
Queued -
Canceled
Steps
In the left navigation pane, click Monitor.
In the Monitor page, click Jobs.
In the Jobs page, perform the following steps:
Click
to filter the list so that only clone operations are listed. -
Specify the start and end dates.
From the Type drop-down list, select Clone.
From the Status drop-down list, select the clone status.
Click Apply to view the operations that are completed successfully.
Select the clone job, and then click Details to view the job details.
In the Job Details page, click View logs.
