SnapCenter cmdlets
Add-SdLunMap
Maps your LUN to an igroup.
Syntax
Add-SdLunMap [-StorageSystem]  <String>  [-LunPath]  <String>  [-Igroup]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Maps your LUN to an igroup. You can use this on the storage system level, for Data ONTAP storage systems. If you are performing provisioning operations, use New-SdStorage.
Name Description Required? Pipeline Input Default Value
StorageSystem
Specifies the storage system on which the igroup to which you want to map your LUN is located.
true
true (ByPropertyName)
LunPath
Specifies the LUN on your storage system.
true
Igroup
Specifies the igroup to which you want to map your LUN.
true
Session
Specifies the session ID from Open-SmConnection. For internal use only.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Maping a LUN to an igroup on an ONTAP storage system
 Add-SdLunMap -StorageSystem svm1 -LunPath /vol/vol1/lun1 -Igroup “myTestIgroup"
This example syntax maps the LUN called lun1 to the igroup"myTestIgroup" on svm1.
