SnapCenter 4.7 cmdlets
Add-SmServer
Adds the SC server to the High Availability cluster
Syntax
Add-SmServer [-Credential]  <PSCredential>  [-ServerNameString]  <String>  [-ServerIPString]  <String>  [-CleanUpSecondaryServerSwitchParameter]  <String>
Detailed Description
Adds the given SC server to the existing High Availability cluster as secondary node. SnapCenter repository data from primary server will be replicated to the secondary server for HA.
Name Description Required? Pipeline Input Default Value
Credential
Provides domain user credentials for the user to setup High Availability cluster configuration.
true
true (ByPropertyName)
ServerName
Secondary SC server name.
false
false
ServerIP
Secondary SC server IP Address.
true
false
Specifies whether to cleanup secondary server. The value is either True or False.
false
false
Example 1: Adding SnapCenter Server to High Availability cluster
 Add-SmServer -Credential sddev\administrator -ServerIP 10.225.231.149
This example Adds SnapCenter Server to High Availability cluster.
Name: Adding SC Server 10.225.231.149 to High Availability cluster
StartTime   : 9/10/2019 4:11:38 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
Monitor the progress of job 105 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 105'
