SnapCenter 4.7 cmdlets
Cancel-SmJob
Cancels backup, clone, and verification jobs, which are in queued state. This cmdlet also cancels the running SnapCenter Plug-in for SQL Server and SnapCenter Plug-in for Oracle backup jobs.
Syntax
Cancel-SmJob [-JobId]  <Int32>  [-Force]  <>
Detailed Description
Enables you to cancel the queued backup, clone, and verification jobs, as well as the running restore and clone jobs for all plug-ins. You can also cancel the running SnapCenter Plug-in for SQL Server and SnapCenter Plug-in for Oracle backup jobs.This cmdlet does not cancel running backup jobs for SnapCenter Plug-in for Exchange, SnapCenter Plug-in for VMware vSphere, SnapCenter Plug-in for SAP HANA, or SnapCenter Custom Plug-ins.This cmdlet replaces the Cancel-SmQueuedJob cmdlet that was available in earlier versions of SnapCenter.
Name Description Required? Pipeline Input Default Value
JobId
Specifies the ID of the job you want to cancel.
true
false
Force
This optional parameter cancels a hung job that is running or queued.
false
false
Example 1: Canceling a Running/Queued job
 Cancel-SmJob -JobId 231
This example syntax cancels the backup job which is either running or queued.
Cancel-SmJob
Job 231 will be canceled. Do you want to continue?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Canceling a Running/Queued job with Force option
 Cancel-SmJob -JobId 231 -Force
This example syntax cancels the backup job which is hung during canceling or running state.
Cancel-SmJob
