SnapCenter cmdlets
Connect-SdIscsiTarget
Establishes a session with your specified iSCSI target.
Syntax
Connect-SdIscsiTarget [-TargetNodeAddress]  <String>  [-TargetPortalAddress]  <String>  [-TargetPortalPortNumber]  <UInt16>  [-InitiatorPortalAddress]  <String>  [-CHAPUserName]  <String>  [-CHAPPassword]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Establishes a session with your specified iSCSItarget.
Name Description Required? Pipeline Input Default Value
TargetNodeAddress
Specifies the target node address.
true
true (ByPropertyName)
TargetPortalAddress
Specifies the target portal address.
true
Specifies the target portal port number.
false
Specifies the initiator portal address.
false
CHAPUserName
Specifies your CHAP user name.
false
CHAPPassword
Specifies your CHAP password.
false
Session
Specifies the session ID from Open-SmConnection. For internal use only.
false
Host
Specifies the name of the computer or host on which the SnapCenter Plug-in for Microsoft Windows service you want to perform the operation runs. The default is your local machine.
false
Example 1: Connecting to an iSCSI target
 PS C:\> Connect-SdIscsiTarget -TargetNodeAddress iqn.1992-08.com.netapp:sn.54053432d1f311e19455123478563412:vs.5 -TargetPortalAddress 172.17.175.84 -TargetPortalPortNumber 3260
This example syntax connects you to an iSCSI target.
