SnapCenter 4.7 cmdlets
Connect-SdStorage
Connects a Windows disk to a LUN.
Syntax
Connect-SdStorage [-Path]  <String>  [-LunPath]  <String>  [-StorageSystem]  <String>  [-SharedDisk]  <>  [-ClusteredSharedVolume]  <>  [-Igroup]  <String>  [-InitiatorInfo]  <HostInitiatorInfo>  [-PortSet]  <String>  [-AutoPickPortSet]  <>  [-AutopickMountPoint]  <>  [-ResourceGroup]  <String>  [-RawDeviceMapping]  <>  [-Datastore]  <String>  [-FileSystemLabel]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Connects a dedicated disk, shared disk, or a clustered shared volume based on a LUN.
Name Description Required? Pipeline Input Default Value
Path
Specifies the drive letter or mount point: D:, D:\
false
true (ByPropertyName)
LunPath
Specifies your LUN path using this format: /vol/volx/lunx
true
StorageSystem
Specifies the target virtual storage machine that you are going to use for provisioning.
true
SharedDisk
Indicates whether you need to provision your Windows disk as a shared disk.
false
Indicates whether you will provision your Windows disk as a Clustered Shared Volume.
false
Igroup
Specifies the igroup you want to use for mapping the LUN. If not specified, SnapCenter Plug-in for Microsoft Windows automatically manages the igroup for mapping the LUN.
false
InitiatorInfo
Specifies the initiators you want to add to your Igroup.
false
PortSet
Specifies the portset you want to use for binding your igroup. If your igroup is already bound to a different portset, specifying this parameter unbinds your igroup and then binds it to the portset specified here.
false
AutoPickPortSet
Indicates whether you want SnapCenter Plug-in for Microsoft Windows to handle the portset binding automatically.
false
AutopickMountPoint
Specifies whether SnapCenter Plug-in for Windows automatically picks the drive letter/volume mount point for the connected disk.
false
ResourceGroup
Specifies the Cluster Resource Group you want to use for a shared disk.
false
RawDeviceMapping
Specifies whether the disk is provisioned as RAW device Mapping.
false
Datastore
Specifies whether the datastore is to be used for RDM.
false
FileSystemLabel
Specifies the label you want to attach to your new Windows volume.
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies your target host.
false
Example 1: Connecting to a dedicated Windows disk
 PS C:\> connect-sdstorage -StorageSystem  172.17.165.31 -path V: -LunPath /vol/santest/b09
In this example syntax, you connect to a dedicated disk.
Example 2: Connecting to a shared Windows disk
 PS C:\> connect-sdstorage -StorageSystem  172.17.165.31 -path V: -LunPath /vol/santest/b09 -SharedDisk -ResourceGroup prod
In this example syntax, you connect to a shared disk.
Example 3: Connecting to a Clustered Shared Volume
 PS C:\> connect-sdstorage -StorageSystem  172.17.165.31 -LunPath /vol/santest/b09  -ClusteredSharedVolume
In this example syntax, you connect to a Clustered Shared Volume.
