SnapCenter cmdlets
Dismount-SdSnapshot
Facilitates dismounting the list of SMB shares that are mounted from the specified Snapshot copy as a different set of shares. Facilitates dismounting the list of LUNs mounted from the specified Snapshot copies as a different set of LUNs.
Syntax
Dismount-SdSnapshot [-Path]  <Object[]>  [-DeleteParentClones]  <>  [-IgnoreVolumeMountPoint]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Facilitates dismounting the list of SMB shares that are mounted from the specified Snapshot copy as a different set of shares. Facilitates dismounting the list of LUNs mounted from the specified Snapshot copies as a different set of LUNs.You can use this cmdlet during backup verification operations. First, you can use Mount-SdSnapshot to mount database and log shares or LUNs from the Snapshot copy. Next, you perform verification operations. After the backup verification is completed, use this cmdlet to dismount the shares/LUNs.If multiple paths contain one or more invalid paths specified in the cmdlet, the command fails for all the paths in the input.Related cmdlets: Mount-SdSnapshot
Name Description Required? Pipeline Input Default Value
Path
Specifies a comma-separated list of SMB shares, disks, or LUN mount points you want to dismount.You cannot mix a logical disk or mount point with SMB shares in the same input path.
true
true (ByValue, ByPropertyName)
DeleteParentClones
false
true (ByPropertyName)
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation.For SMB shares, the default is your local machine.For LUNs, you must provide this parameter.
false
Example 1: Dismounting multiple shares that were mounted from a Snapshot copy
 PS C:\> Dismount-SdSnapshot -Path "\\SQLFileserver\DBShareSdClone607fb343_2b3c_41f6_8912_8762a1800290","\\SQLFileserver\DBShareSdClone6bcf3df5_3384_4ba4_9b33_25bb9636a486"
This example syntax specifies how to dismount your Snapshot copies mounted on the specified shares.
Example 2: Dismounting a Snapshot of a LUN
 PS C:\> Dismount-SdSnapshot -Path I: -Host Host1.DMN.COM
This example syntax specifies how to dismount your Snapshot copy mounted on the specified drive.
Example 3: Dismounting multiple mount points
 PS C:\> Dismount-SdSnapshot -Path "C:\scmnpt\mpdisk0005\","C:\scmnpt\mpdisk0006\" -Host Host1.DMN.COM
This example syntax specifies how to dismount your Snapshot copies mounted on the specified mount points.
