SnapCenter 4.7 cmdlets
Enable-SmRepositoryHAConfig
Enables SnapCenter repository HA configuration.
Syntax
Enable-SmRepositoryHAConfig [-SlaveNode]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
SlaveNode
Specifies the IP address of the slave node. This IP must not belong to the master node IP or IP of the machine where this cmdlet is running.
true
true (ByPropertyName)
Example 1: Enabling SnapCenter repository HA config
 Enable-SmRepositoryHAConfig -SlaveNode "slave_node_ip_address"
This example syntax enables SnapCenter repository HA config. Slave node IP must not belong to the master node IP or IP of the machine where this cmdlet is running. This cmdlet must be executed on the Master (primary) node.
Are you sure you want to enable MySQL HA Configuration ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
SnapCenter repository HA configuration is successfully configured.
