SnapCenter 4.7 cmdlets
Get-SdIgroup
Gets information about available igroups.
Syntax
Get-SdIgroup [-Name]  <String[]>  [-Initiators]  <String[]>  [-LunPath]  <String>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the igroups about which you want to retrieve information.
false
true (ByPropertyName)
Initiators
Specifies any initiators included in the igroup.
false
LunPath
Specifies the LUN on your storage system.
false
StorageSystem
Specifies the storage system on which the igroup resides.
true
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Retrieving igroup information
 PS C:\> Get-SdIgroup -StorageSystem 172.17.168.13
This exmaple syntax retrieves the igroup information for the specified storage system.
