SnapCenter 4.7 cmdlets
Get-SmAlert
Get details of the alert(s).
Syntax
Get-SmAlert [-AlertId]  <String>  [-Severity]  <SmAlertSeverity>  [-Status]  <SmAlertStatus>  [-EntityType]  <SmEntityType>  [-SearchText]  <String>
Detailed Description
Get details of the alerts. This information includes the alert name, description, recommendation, severity, status, entity, etc.
Name Description Required? Pipeline Input Default Value
AlertId
Specify the Id of the alert.
false
true (ByPropertyName)
Severity
Specify the severity of the alert(s) needs to be filtered. ("Informational", "Warning", "Critical")
false
Status
Specify the status of the alert(s) needs to be filtered. ("New", "Resolved")
false
EntityType
Specify the entity type of the alert(s) needs to be filtered. ("SnapCenterServer", "Host", "StorageSystem")
false
SearchText
Specify the Alert Name or Entity Name needs to be filtered.
false
Example 1: Get alert by Id
 Get-SmAlert -AlertId 100
This example syntax retrieves the information of an alert.
CreatedTime: 12/5/2018 2:47:05 AM
ModifiedTime   : 12/5/2018 2:47:05 AM
Name   : Aggregate assignment check
Status : New
Severity   : Warning
Entity : SMCoreContracts.ConfigCheck.SmEntity
Description: Aggr-list field is not set for the storage virtual machine
Recommendation : To rectify this issue, see https://kb.netapp.com/app/answers/answer_view/a_id/1070989/loc/en_US
JobId  : 2345
Source : Server
EntityType : Host
EntityName : mtme.englab.netapp.com
Example 2: Get all alerts
 Get-SmAlert
This example syntax retrieves the information about all alerts.
Status : New
Severity   : Warning
JobId  : 2345
Source : Server
EntityType : Host
EntityId   : 1
CreatedTime: 12/5/2018 2:48:15 AM
ModifiedTime   : 12/5/2018 2:48:15 AM
Name   : IMT check - OS platform, version and patches for SCSQL Server
Status : New
Severity   : Critical
Description: Unsupported version of SQL server instance is detected for the host
Recommendation : Please refer to NetApp Interoperability Matrix Tool for supported versions
JobId  : 3456
Source : Server
EntityType : Host
EntityId   : 1
CreatedTime: 12/5/2018 2:57:23 AM
ModifiedTime   : 12/5/2018 2:57:23 AM
Name   : SVM duplicate Data LIF check
Status : New
Severity   : Warning
Description: Cluster Storage Virtual Machines have duplicate IP address
Recommendation : You should ensure that ONTAP Cluster storage virtual machine network interfaces have unique IP addresses assigned to them
JobId  : 3678
Source : Server
EntityType : SVM
EntityName : mtme-win2k8r2x64-20.gdl.englab.netapp.com
EntityId   : 1
Example 3: Get all the alerts based on severity
 Get-SmAlert -Severity "Critical"
This example syntax retrieves all the critical alerts.
Status : New
Severity   : Critical
JobId  : 3456
Source : Server
EntityType : Host
EntityId   : 1
Example 4: Get all the alerts based on status
 Get-SmAlert -Status "New"
This example syntax retrieves all the new alerts.
Status : New
Severity   : Critical
JobId  : 3456
Source : Server
EntityType : Host
EntityId   : 1
Example 5: Get all the alerts based on entity
 Get-SmAlert -EntityType "Host"
This example syntax retrieves all the Host related alerts.
Status : New
Severity   : Critical
JobId  : 3456
Source : Server
EntityType : Host
EntityId   : 1
Example 6: Get all the alerts based on entity name
 Get-SmAlert -SearchText "mtme.englab"
This example syntax retrieves all the alerts whose entity name contains the text 'mtme.englab'.
Status : New
Severity   : Critical
JobId  : 3456
Source : Server
EntityType : Host
EntityId   : 1
