SnapCenter 4.7 cmdlets
Get-SmBackup
Gets information about one or more backups.
Syntax
Get-SmBackup [-BackupName]  <String>  [-BackupId]  <String>  [-AppObjectName]  <String>  [-AppObjectId]  <String>  [-Secondary]  <>  [-CloudProtected]  <>  [-Details]  <>
Detailed Description
Gets information about one or more backups. You can specify whether to include information about secondary backups.
Name Description Required? Pipeline Input Default Value
BackupName
Specifies the name of the backup about which you want to retrieve information.
false
true (ByPropertyName)
BackupId
Specifies the ID of the backup about which you want to get information.
false
AppObjectName
Specifies the name of the application object.
false
AppObjectId
Specifies the ID of the application object.
false
Secondary
Specifies whether to list only the secondary backups.
false
CloudProtected
Specifies whether to list only the cloud backups.
false
Details
false
Example 1: Getting information about all backups
 Get-SmBackup
This example syntax gets information about all available backups.
BackupId BackupName BackupTime BackupType
1 Payroll Dataset_vise-f6_08…​ 8/4/2015 11:02:32 AM Full Backup
2 Payroll Dataset_vise-f6_08…​ 8/4/2015 11:23:17 AM
Example 2: Getting information about secondary backups
 Get-SmBackup -Secondary
This example syntax gets information about only secondary backups.
Example 3: Getting a backup information for a specific backup name
 Get-SmBackup -BackupName "Payroll Dataset_vise-f6_08-04-2015_11.02.10.3432"
This example syntax gets backup information for the specified backup name.
Example 4: Getting backup information using the backup ID
 Get-SmBackup -BackupId 1
This example syntax gets backup information using the specified backup ID.
Example 5: Getting backup information using the resource ID
 Get-SmBackup -AppObjectId vise-f6\PayrollDatabase
This example syntax gets backup information using the specified resource ID.
