SnapCenter cmdlets
Get-SmConfigSettings
Displays the configuration settings for the SnapCenter Server host or a SnapCenter plug-in host.
Syntax
Get-SmConfigSettings [-Server]  <>  [-Key]  <String>  [-Agent]  <>  [-HostName]  <String>  [-Key]  <String>  [-Plugin]  <>  [-HostName]  <String>  [-PluginCode]  <PluginCode>  [-Key]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Server
Displays the configuration values for the server on which SnapCenter is installed.
true
false
Key
Specifies the configuration key information you want to display. You can specify a specific key name or specify All to display all configuration information. You can specify multiple keys in to double quotation with Comma (like : "RESTTimeout,MaxVerificationJobPerServer").
true
false
Agent
Displays the configuration values for the SMCore agent.
true
false
HostName
Specifies the name or IP address of the host, only when the Agent or Plugin parameters are specified.
true
false
Plugin
Displays the configuration information of the plug-in host.
true
false
PluginCode
Specifies which plug-in configuration you want to display. Valid values are SCSQL and SCO.
true
false
Example 1: Getting configuration settings on a custom plugin host
 Get-SmConfigSettings -Agent -HostName SNAPCENTER113.sccore.test.com -Key all
This example syntax gets all configuration settings on custom plug-in host.
Key: PLUGIN_OPERATION_TIMEOUT_IN_MSEC   Value: 3600000  Details: Plug-in API operation Timeout
Key: SERVER_API_TIMEOUT_IN_SEC  Value: 180  Details: Web Service API Timeout
Key: ALLOWED_CMDS   Value: *;   Details: Allowed Host OS Commands
Example 2: Getting configuration value for a specific custom plugin configuration parameter
 Get-SmConfigSettings -Agent -HostName SNAPCENTER113.sccore.test.com -Key ALLOWED_CMDS
This example syntax gets the configuration parameter value for the key ALLOWED_CMDS settting on the custom plug-in host.
Key: ALLOWED_CMDS Value: mount *; unmount *; Details: Allowed Host OS Commands
PS C:\Users\administrator.SCCORE>
Example 3: Getting a single configuration value for the SnapCenter Server
 Get-SmConfigSettings -Server -Key WindowsRemoteInstallProcessTimeout
This example syntax displays the configuration value for a single SnapCenter Server key.
Key: WindowsRemoteInstallProcessTimeout Value: 900 Details: Windows remote install/uninstall process wait time (in seconds).
Example 4: Getting a more than one configuration values for the SnapCenter Server
 Get-SmConfigSettings -Server -Key "RESTTimeout,MaxVerificationJobPerServer"
Key: RESTTimeoutValue: 10800000   Details: REST Timeout for SnapManager proxy (in milliseconds).
Key: MaxVerificationJobPerServerValue: 20 Details: Maximum verification job that can be run per server.
Example 5: Getting all configuration settings on a plugin host including custom port
 Get-SmConfigSettings -Agent 10.236.172.64 -Key all
This example syntax displays all the configuration settings for a plug-in host, including the custom SMcore port.
Key: SMSServerURL   Value: https://WINDOWS-D38M60U.englab.netapp.com:8146 Details: SMS server url.
Key: SMSServer  Value: localhost  Details: SMS server.
Key: VSCProtocolValue: https  Details: VSC protocol.
Key: RESTTimeoutValue: 10800000   Details: REST Timeout for SMCore proxy (in milliseconds).
Key: RESTConnectionLimitValue: 1500   Details: The maximum number of concurrent connections allowed on REST endpoi
nt.
Key: ServicesBaseAddressValue: https://localhost:8152 Details: Service base address.
Key: SnapCenterServerVersionValue: 1.0.0.0Details: SnapCenter server version.
Key: PSDirectoryValue: WindowsPowerShell\v1.0\Modules\SnapCenter\log  Details: PS directory.
Key: smcoreport Value: 8152   Details: SMCore port.
