Get-SmDownloadRepository
Provides the SnapCenter Server repository path on the local host. SnapCenter uses this path to store Compatibility File and plug-in installation packages.
Syntax
Detailed Description
Provides the SnapCenter Server repository path on the local host. SnapCenter uses this path to store Compatibility File and plug-in installation packages.You can also use this cmdlet after the Set-SmDownloadRepository cmdlet to verify changes to the installation package download repository.
| Name | Description | Required? | Pipeline Input | Default Value |
Example 1: Verifying the plugin installation download repository location
This example syntax verifies the location of the plug-in installation download repository.
O:\inetpub\wwwroot\SnapCenter\Repository\
