Get-SmMultiFactorAuthentication
Gets the MFA configuration of the SnapCenter Server.
Syntax
Get-SmMultiFactorAuthentication [-] <>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Example 1: Get MultiFactorAuthentication configuration
This example syntax gets the MFA configuration of the SnapCenter Server.
ISMFAEnabled = True
ADFSHostName = adfs19.ad19domain.com
ADFSConfigFilePath = C:\\ADFS_metadata\\FederationMetadata.xml
SCConfigFilePath = c:\ProgramData\NetApp\SnapCenter\Package Repository\SnapCenterMFAMetadata.xml
