SnapCenter 4.7 cmdlets
Get-SmRepositoryBackups
Gets the backup and saves the metadata to the active file system (AFS).
Syntax
Get-SmRepositoryBackups [-Hostname]  <String>  [-SMSbaseUrl]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Hostname
Specifies the SnapCenter database host name. If the SnapCenter database is hostedby a failover cluster instance (FCI), then specify the FCI owner host name.
false
true (ByPropertyName)
SMSbaseUrl
Specifies the SnapCenter Server URL. This is required when executing a PowerShell command from a plug-in machine. For example:-SMSbaseUrl https://172.17.166.128:8146
false
Example 1: Retrieving repository backups
This example syntax retrieves repository backups.
