SnapCenter 4.7 cmdlets
Get-SmRestoreReport
Initiates a restore report.
Syntax
Get-SmRestoreReport [-JobId]  <Int64>  [-FromDateTime]  <DateTime>  [-ToDateTime]  <DateTime>  [-Resource]  <String>  [-Plugin]  <PluginCode>  [-HostName]  <String>
Detailed Description
Initiates a restore report. The restore report tells you which resource was restored on which host and the job status. You can specify the time range for which you want this report. The default time range is the last 7 days. You can also query for restore information about an individual resource. For any integer value provided for date, value is taken as 1/1/0001 12:00 AM.
Name Description Required? Pipeline Input Default Value
JobId
To be deleted.
true
true (ByPropertyName)
FromDateTime
Specifies that you want to get a restore report for restore jobs run between a specified day and time. This option provides the start date and time. You can specify the date and time using any date and time format string. For example, "2/2/2015 8:52PM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone.
false
false
ToDateTime
Specifies that you want to get a restore report for restore jobs run between a specified day and time. This option provides the end date and time. You can specify the date and time using any date and time format string. For example, "2/2/2015 8:52PM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone.
false
false
Resource
Provides the name of a specific resource for which you want to get a restore report.
false
Plugin
Specify the plug-in code to generate the report. For custom plug-ins, specify the custom plug-in name for example, hana, mysql.
false
HostName
Specifies the name of the host on which the restore was taken.
false
Example 1: Getting a restore report
 Get-SmRestoreReport
This example syntax gets a restore report.
SmJobId   : 2516
StartDateTime : 2/4/2015 1:09:15 PM
EndDateTime   : 2/4/2015 1:09:57 PM
Status: Completed
Resource  : SMCoreContracts.SmObject
RecoveryRequest   :
PluginCode: SCO
PluginName: Oracle Database
PluginDisplayName : Oracle Database
SmJobId   : 2535
StartDateTime : 2/5/2015 6:02:19 AM
EndDateTime   : 2/5/2015 6:03:13 AM
Status: Completed
RecoveryRequest   :
PluginCode: SCC
PluginName: SAP HANA
PluginDisplayName : SAP HANA
Example 2: Getting a restore report for a specific resource
 Get-SmRestoreReport -Resource TestDb3
This example syntax gets a report on restores performed for the given resource.
SmJobId   : 2516
Status: Completed
RecoveryRequest   :
PluginCode: SCC
Example 3: Getting a restore report for a specific host
 Get-SmRestoreReport  -HostName SCSPR0019366001.gdl.mycompany.com
This example syntax gets a restore report for all resources on the given host.
SmJobId   : 2516
Status: Completed
RecoveryRequest   :
PluginCode: SCO
SmJobId   : 2535
Status: Completed
RecoveryRequest   :
PluginCode: SCC
