Get-SmSnapCenterVersion
Gets the SnapCenter Server version and build number.
Syntax
Get-SmSnapCenterVersion [-] <>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Example 1: Get SnapCenter Server Version
This example syntax gets the installed SnapCenter Server version and build number.
ServerVersion : 4.5.0.6127 PluginVersion : ProductVersion : 4.5 ProductName: SnapCenter Server 4.5 Result : SMCoreContracts.SMResult TotalCount : 0 DisplayCount : 0 Context: Job: SMCoreContracts.SmJob
