Get-SmUserAssignedPermission
Retrieves information about the permissions associated with a specified user.
Syntax
Get-SmUserAssignedPermission [-Name] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
Names the domain\user about whom you want to retrieve permission information. |
true |
true (ByPropertyName) |
Example 1: Getting permissions associated with a user
Get-SmUserAssignedPermission -Name sddev\administrator
This example syntax displays the permissions associated with the specified user.
AttribCode : create Name : Backup Type : Id : 9 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Backup Type : Id : 10 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Host Type : Id : 15 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : DataSet Type : Id : 3 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Provision Type : Id : 27 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Clone Type : Id : 23 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Discovery Type : Id : 54 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Restore Type : Id : 53 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Backup Type : Id : 10 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Host Type : Id : 13 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Host Type : Id : 14 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Host Type : Id : 15 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Host Type : Id : 16 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : DataSet Type : Id : 3 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Policy Type : Id : 8 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Provision Type : Id : 25 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Provision Type : Id : 26 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Provision Type : Id : 27 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Provision Type : Id : 28 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Clone Type : Id : 23 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : StorageConnection Type : Id : 17 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : StorageConnection Type : Id : 18 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : StorageConnection Type : Id : 19 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : StorageConnection Type : Id : 20 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : DashBoard Type : Id : 51 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Discovery Type : Id : 54 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Plugin_Installation Type : Id : 58 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Reports Type : Id : 52 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0
