SnapCenter 4.7 cmdlets
Install-SmHostPackage
Installs or upgrades a host plug-in package on one or more hosts.
Syntax
Install-SmHostPackage [-HostNames]  <String>  [-PluginCodes]  <UploadedPluginCode>  [-PluginVersions]  <Hashtable>  [-InstallPath]  <String>  [-SkipPreinstallChecks]  <SwitchParameter>  [-GMSAName]  <String>  [-Force]  <SwitchParameter>
Detailed Description
Installs or upgrades a host plug-in package on one or more hosts. When specifying multiple hosts, all hosts must have the same OS.
Name Description Required? Pipeline Input Default Value
HostNames
Specifies the hosts on which you want to install or upgrade the plug-in. You can specify one host, or multiple, comma-separated host names. Host names must be entered using the format -HostNames @("hostname") when installing to a single host, or -HostNames @("hostname1", "hostname2") when installing to multiple hosts. You can specify the hostname using either the host FQDN or IP address.
true
true (ByPropertyName)
PluginCodes
Specifies the code for one or more plug-ins in the packages that you want to install. The following values are valid: SCSQL, SCO, SCW, SCE and hana.For custom plug-ins, the value is the custom plug-in name. For example "CustomPlugin1".You can use a comma-separated list of plug-in codes to install multiple plug-ins.
true
PluginVersions
Specifies in a hash table the custom plug-in name and the version to install. The PluginVersions parameter uses the format @{"customplugin" = "4.0"}
false
InstallPath
Specifies the plug-in installation path, if the path different from the default.
false
Specifies that installation prechecks will not be triggered.
false
GMSAName
Specifies that group Managed Service Account (gMSA) name will be used to run the plug-in services.
false
Force
Internal switch.
false
Example 1: Installing SnapCenter Plug-in for Microsoft SQL Server and SnapCenter Plug-in for Microsoft Windows on a Windows host
 Install-SmHostPackage -HostNames @("host2012r2.mycompany.com") -PluginCodes SCSQL,SCW
This example syntax installs SnapCenter Plug-in for Microsoft SQL Server and SnapCenter Plug-in for Windows on the specified host.
Example 2: Installing SnapCenter Plug-in for Microsoft SQL Server and SnapCenter Plug-in for Microsoft Windows on multiple hosts
 Install-SmHostPackage -HostNames @("sql-1.mycompany.com", "sql-2.mycompany.com") -PluginCodes SCSQL,SCW
This example syntax installs SnapCenter Plug-in for Microsoft SQL Server and SnapCenter Plug-in for Microsoft Windows on multiple hosts.
Example 3: Installing a custom plug-in with SnapCenter Plug-in for Oracle and SnapCenter Plug-in for Unix on a Linux host
 Install-SmHostPackage -HostNames("scspr0098708001.englab.mycompany.com") -PluginCodes CustomPlugin1,SCO -InstallPath /opt/NetApp/snapcenter/ -PluginVersions  @{"customplugin1" = "2.0"}
This example syntax installs a custom plug-in along with SnapCenter Plug-in for Oracle and SnapCenter Plug-in for Unix on a Linux host.
Example 4: Installing SnapCenter Plug-in for Microsoft Exchange Server
 Install-SmHostPackage -HostNames Exchange2016DAG -PluginCodes SCE,SCW -Verbose
This example syntax installs SnapCenter Plug-in for Microsoft Exchange Server on the specified host.
Example 5: Installing SnapCenter Plug-in for SAP HANA Database on the same Windows host
 Install-SmHostPackage -HostNames 'Windows.Host.lab.com' -PluginCodes hana,SCW
This example syntax installs the SnapCenter Plug-in for SAP HANA Database on the same host where SnapCenter Server is installed.
Example 6: Installing SnapCenter Plug-in for SAP HANA database on a remote host
 Install-SmHostPackage -HostNames 'Host.fqdn.lab.com' -PluginCodes hana
This example syntax installs the SnapCenter Plug-in for SAP HANA Database on the specified remote host (Windows and Linux).
Example 7: Installing SnapCenter Plug-in for Oracle Database on a AIX host
 Install-SmHostPackage -HostNames 'aix207-193.gdl.englab.netapp.com' -PluginCodes SCO
This example syntax installs the SnapCenter Plug-in for Oracle Database on the specified AIX host. Plugin code SCC is not supported.
Example 8: Installing SnapCenter Plug-in for Microsoft SQL Server and SnapCenter Plug-in for Microsoft Windows on a Windows host to run with group Managed Service Account (gMSA)
 Install-SmHostPackage -HostNames 'host2012r2.NewDomain.com' -PluginCodes SCSQL,SCW -GMSAName 'NewDomain\gMSAName$'
This example syntax installs SnapCenter Plug-in for Microsoft SQL Server and SnapCenter Plug-in for Windows to run with the mentioned group Managed Service Account (gMSA) name on the specified host.
