SnapCenter 4.7 cmdlets
Invoke-SdEmsAutosupportLog
Facilitates logging Event Management System (EMS) AutoSupport messages.
Syntax
Invoke-SdEmsAutosupportLog [-Path]  <Object>  [-EventId]  <Int32>  [-EventSource]  <String>  [-AppVersion]  <String>  [-Category]  <String>  [-EventDescription]  <String>  [-LogLevel]  <UInt32>  [-GenerateAutosupport]  <>  [-Session]  <String>  [-Host]  <String>  [-StorageSystem]  <String>  [-EventId]  <Int32>  [-EventSource]  <String>  [-AppVersion]  <String>  [-Category]  <String>  [-EventDescription]  <String>  [-LogLevel]  <UInt32>  [-GenerateAutosupport]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Facilitates logging Event Management System (EMS) AutoSupport messages. You can use this cmdlet to determine the underlying administration server, and to send messages to that server, for your specified SMB share or logical disk. Your application can use this cmdlet to log events with different severity levels in EMS and to send corresponding AutoSupport messages about backup, restore, and similar operations, errors, or failures. Related cmdlets: Get-SdSMBShadowCopyEmsMessage
Name Description Required? Pipeline Input Default Value
Path
Specifies the ID for the SMB share, logical disk to which you send the EMS AutoSupport message.You cannot mix a logical disk or mount point with SMB shares in the same input path.
true
true (ByValue, ByPropertyName)
EventId
Provides the event ID. This is a user-defined event ID, with a range from 0 to 2^32-2.
true
true (ByPropertyName)
EventSource
Indicates the application invoking the cmdlet.
true
AppVersion
Provides the version of the application invoking the cmdlet.
true
Category
Specifies an application-defined event category.
true
EventDescription
Describes the event you want to log. The event description is an application-defined message.
true
LogLevel
Indicates the EMS message severity. Accepted values are: 0 for "emergency"; 1 for "alert"; 2 for "critical"; 3 for "error";4 for "warning";5 for "notice";6 for "info";7 for "debug"
true
GenerateAutosupport
Specifies that you want to generate an AutoSupport message.
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
StorageSystem
Names the storage system for resources to which you send the EMS AutoSupport message.
true
Example 1: Logging a test EMS AutoSupport message
 PS C:\> Invoke-SdEmsAutosupportLog -Path \\172.17.165.40\root -EventId 111 -EventSource "SDW" -AppVersion "1.0" -Category "test" -EventDescription "This is testing message from NextGenSDW." -LogLevel 6
In this example syntax, you send a test EMS log message to the virtual storage server to which the SMB share belongs. The cluster server display the following message:
TimeNode Severity  Event
8/14/2012 11:47:54  mvaqa-3270-1-01  INFORMATIONAL app.log.info: SNAPMGR-06: SDW 7.0: (111) test: This is testing message from SnapDrive.
Example 2: Logging and generating a test EMS AutoSupport message
 PS C:\> Invoke-SdEmsAutosupportLog -Path \\172.17.165.40\root -EventId 111 -EventSource "SDW" -AppVersion "1.0" -Category "test" -EventDescription "This is testing message from SnapDrive." -LogLevel 6 -GenerateAutosupport
In this example syntax, you log a test message in EMS and send an AutoSupport message to the virtual storage server to which the SMB share belongs.
Example 3: Logging a test EMS AutoSupport message in a clustered environment
 PS C:\> Invoke-SdEmsAutosupportLog -Path E: -EventId 111 -EventSource "SDW" -AppVersion "1.0" -Category "test" -EventDescription "This is testing message from SnapDrive." -LogLevel 6
The cluster server displays the following message:
Example 4: Logging a test EMS AutoSupport message using a storage system
 PS C:\> Invoke-SdEmsAutosupportLog -StorageSystem 172.17.165.39 -EventId 111 -EventSource "SDW" -AppVersion "1.0" -Category "test" -EventDescription "This is testing message from SnapDrive." -LogLevel 6
In this example syntax, you send a test EMS log message to the virtual storage server used as the storage system.
------------------  ---------------  ------------  -------------------------   11/15/2012 16:13:43 mvaqa-3270-1-02  INFORMATIONAL app.log.info: CLAB-A13-10: SDW 7.0: (111) test: This is testing message from SnapDrive.
