SnapCenter 4.7 cmdlets
Invoke-SdHostVolumeSpaceReclaim
Initiates space reclamation on your host volume.
Syntax
Invoke-SdHostVolumeSpaceReclaim [-Path]  <String>  [-Session]  <String>  [-Host]  <String>  [-UnmapSize]  <String>  [-VdsId]  <Guid>  [-Session]  <String>  [-Host]  <String>  [-UnmapSize]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Path
The mount point (i.e. G:\) or path to any file on the volume to process.
true
true (ByValue, ByPropertyName)
Session
Specifies the session ID from Open-SmConnection.
false
true (ByPropertyName)
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
UnmapSize
Specifies the size of the blocks you want to reclaim. The size should be greater than 0 and less than 2147483648 bytes.
false
false
VdsId
Specifies your virtual disk service ID.
true
Example 1: Reclaiming space
 PS C:\> Invoke-SdHostVolumeSpaceReclaim -Path E:
This example syntax reclaims space no longer being used by the host operating system.
