SnapCenter 4.7 cmdlets
Invoke-SmResourceSplit
Initiates the split clone operation.
Syntax
Invoke-SmResourceSplit [-Estimate]  <>  [-AppObjectId]  <String>  [-CloneName]  <String>  [-Start]  <>  [-AppObjectId]  <String>  [-CloneName]  <String>  [-DoNotEstimate]  <>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>  [-Stop]  <>  [-AppObjectId]  <String>  [-CloneName]  <String>  [-Status]  <>  [-AppObjectId]  <String>  [-CloneName]  <String>
Detailed Description
You can use SnapCenter to split the database clone from the parent database. The split clone database becomes independent of the original database.
Name Description Required? Pipeline Input Default Value
Estimate
Specifies that details be provided for volumes that are being split.
false
true (ByValue)
AppObjectId
Specifies the AppObjectId of the clone where the split will be performed.
false
true (ByValue)
CloneName
The name of the clone where the split will be performed.
false
true (ByValue)
EmailBody
false
true (ByPropertyName)
EmailFrom
true
EmailTo
true
EmailSubject
true
EnableEmailAttachment
false
Start
Triggers the split clone operation.
false
true (ByValue)
DoNotEstimate
Specifies that details should not be provided for the volumes that are being split.
false
true (ByValue)
EnableEmail
Enables email notifications.
false
false
EmailPreference
Specifies when you will received email notifications. Possible values include Always, Never, OnError, OnErrorOrWarning.
false
false
Stop
Stops the split clone operation.
false
true (ByValue)
Status
Determines the status of the split clone operation.
false
true (ByValue)
Example 1: Clone split estimate
 Invoke-SmResourceSplit -AppObjectId 'SC14110001040-3\NAMEDINST1\SC14110001040_3_SDML_1_Clone_103255'  -Estimate
This example syntax displays the estimate details for the volume that is going to be split.
Clone Split Estimate Job Summary:
JobId : 221
ListVolumeAggSpaceMapping : {SC14110001040_3_SDML_Data_Vol1115172233091381,
SC14110001040_3_SDML_Log_Vol1115172233079350}
CanSplit  : True
AppObjectId   : SC14110001040_3_SDML_1_Clone_103255
CloneName : ResourceGroup_SDML_45212443__clone__11-15-2017_22.33.25
Result: SMCoreContracts.SMResult
TotalCount: 0
DisplayCount  : 0
Context   :
Job   : SMCoreContracts.SmJob
Estimation Details for the volumes involved in Clone Split:
VolumeName: SC14110001040_3_SDML_Data_Vol1115172233091381
RequiredSpace : 24 MB
AggregateName : aggr_anu
AvailableSpaceInAggregate : 3528 GB
StorageSystem : 10.225.85.51
IsVolumeAlreadySplit  : False
VolumeName: SC14110001040_3_SDML_Log_Vol1115172233079350
RequiredSpace : 22 MB
Example 2: Clone split status
 Invoke-SmResourceSplit -CloneName 'Resource_Group_Instance_45212443__clone__11-15-2017_22.44.24'  -Status
This example syntax displays the status of a clone split operation.
Clone Split Status Job Summary:
JobId: 237
AppObjectId  : SC14110001040_3_MDSL_4_Clone_104322
CloneName: Resource_Group_Instance_45212443__clone__11-15-2017_22.44.24
Result   : SMCoreContracts.SMResult
TotalCount   : 0
DisplayCount : 0
Example 3: Starting a clone split operation
 Invoke-SmResourceSplit -CloneName 'Resource_Group_Instance_45212443__clone__11-15-2017_22.44.24'  -confirm:$false  -Start
This example syntax starts a clone split operation.
Clone Split Start Job Summary:
JobId: 238
TotalCount   : 0
DisplayCount : 0
Context  :
Example 4: Stopping a clone split operation
 Invoke-SmResourceSplit -AppObjectId 'SC14110001040-3\NAMEDINST1\SC14110001040_3_MDML_4_Clone_105129'  -Stop
This example syntax stops a clone split operation.
Clone Split Stop Job Summary:
JobId: 246
AppObjectId  : SC14110001040_3_MDML_4_Clone_105129
CloneName: Resource_Group_Instance_45212443__clone__11-15-2017_22.52.47
TotalCount   : 0
DisplayCount : 0
Context  :
Example 5: Clone split estimate for a SAP HANA MultiTenant Database Container resource clone
 Invoke-SmResourceSplit -Estimate -CloneName SNAPCENTER40.sccore.test.com\hana\H30\H30_cn
This example syntax displays the estimate details for the volume that is going to be split. CloneName may be obtained by running the Get-SmClone command.
JobId : 773
ListVolumeAggSpaceMapping : {ng_pvol04021807440550}
CanSplit  : True
AppObjectId   : H30_cn
CloneName : SNAPCENTER40.sccore.test.com\hana\H30\H30_cn
TotalCount: 0
DisplayCount  : 0
Context   :
VolumeName: ng_pvol04021807440550
RequiredSpace : 48 MB
AggregateName : aggr1_old
AvailableSpaceInAggregate : 4670 GB
StorageSystem : 10.200.200.100
Example 6: Starting a clone split operation for a SAP HANA MultiTenant Database Container resource clone
 Invoke-SmResourceSplit -start -CloneName SNAPCENTER40.sccore.test.com\hana\H30\H30_cn
This example syntax starts a clone split operation. CloneName may be obtained by running the Get-SmClone command.
This may take several minutes to complete for large volumes. All backups taken on the clone will be deleted
Do you still want to continue?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"):
JobId: 774
CloneName: SNAPCENTER40.sccore.test.com\hana\H30\H30_cn
TotalCount   : 0
DisplayCount : 0
Context  :
Example 7: Stopping a clone split operation for a SAP HANA MultiTenant Database Container resource clone
 Invoke-SmResourceSplit -stop -CloneName SNAPCENTER40.sccore.test.com\hana\H30\H30_cn
This example syntax stops a clone split operation. CloneName may be obtained by running the Get-SmClone command
JobId: 775
TotalCount   : 0
DisplayCount : 0
Context  :
