SnapCenter 4.7 cmdlets
Mount-SdClone
Enables cloning and mounting a source storage from the specified Snapshot copy.
Syntax
Mount-SdClone [-SourcePath]  <String[]>  [-Snapshot]  <String>  [-ResourceType]  <ResourceType>  [-Host]  <String>  [-Igroup]  <String>  [-Initiators]  <String>  [-IgroupProtocol]  <IgroupProtocolEnum>  [-IgroupOsType]  <IgroupOSTypeEnum>  [-CheckInitiatorSession]  <>  [-Session]  <String>
Detailed Description
Enables cloning and mounting a source storage from the specified Snapshot copy.For a LUN, the cloned volume name is automatically appended with a unique identifier, while the LUN name remains the same.For example:If the original volume is PrimarySVM:/vol/SCE_VOL, the cloned volume name is PrimarySVM:/vol/SCE_VOL1201210041488133. Related cmdlets: Dismount-SdClone, Get-SmClone, Remove-SmClone, New-SmClone
Name Description Required? Pipeline Input Default Value
SourcePath
Specifies a path that you want to clone and mount from the Snapshot copy. For example, the path of a volume.
true
true (ByValue, ByPropertyName)
Snapshot
Specifies the Snapshot copy that you want to use for cloning and mounting.
true
true (ByPropertyName)
ResourceType
Specifies the type of the resource in the SourcePath parameter. The possible options are: "SDStorageVolume", "SDStorageLunPath", "SDStorageDir".
false
Host
Specifies the FQDN or IP address of the host on which you want to execute the operation.
false
Igroup
false
Initiators
false
IgroupProtocol
false
IgroupOsType
false
false
Session
false
Example 1: Clone a Volume from a given snapshot
 PS C:\> Mount-SdClone -SourcePath Primary_SVM:/vol/VOl1_LM_Port_Issue_Test -Snapshot r70105ec0a5v1_hnk2_com_L__ValidPath_Data_R70105EC0A5V1_05-24-2021_12.46.42.3914
This example syntax specifies the storage volume path and clones the Snapshot copy onto newly cloned volume.
Source Clone
Primary_SVM:/vol/VOl1_LM_Port_Issue_Test Primary_SVM:/vol/Vol1_LM_Port_Issue_Test0525210820263222
Example 2: Clone a volume from a given Snapshot copy with the ResourceType and host name specified
 PS C:\> Mount-SdClone -SourcePath Primary_SVM:/vol/Vol1  -Snapshot Host1_Policy1_12-01-2021_02.31.22.3854  -ResourceType SDStorageVolume -Host Host1.DMN.COM -Verbose
This example syntax specifies the storage volume path and clones the Snapshot copy to a newly cloned volume with the ResourceType and host name.
VERBOSE: Operation successful.
Source Clone
Primary_SVM:/vol/Vol1 Primary_SVM:/vol/Vol11201210243583210
