SnapCenter 4.7 cmdlets
New-SdIgroup
Creates a new igroup.
Syntax
New-SdIgroup [-Name]  <String>  [-Protocol]  <String>  [-Type]  <String>  [-PortSet]  <String>  [-Initiators]  <String[]>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
Specifies the name for your new igroup.
true
true (ByPropertyName)
Protocol
Specifies the protocol you want to use with your new igroup.
true
Type
Specifies the type of igroup you want to create.
false
PortSet
Specifies the portset to which you want to add your igroup.
false
Initiators
Specifies any initiators you want to and to your igroup.
false
StorageSystem
Specifies the storage system on which you want your igroup to reside.
true
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Creating a new igroup
 PS C:\> New-SdIgroup -Name IG_Demo -StorageSystem 172.17.168.13 -Initiators iqn.1991-05.com.microsoft:mva-s24-rx200.sddev.mycompany.com -Protocol mixed
This example syntax creates a new mixed protocol igroup on the specified storage system.
