SnapCenter 4.7 cmdlets
New-SdStorage
Provisions a Windows volume or disk on a LUN.
Syntax
New-SdStorage [-Path]  <String>  [-Size]  <String>  [-LunPath]  <String>  [-StorageSystem]  <String>  [-FileSystemLabel]  <String>  [-SharedDisk]  <>  [-ClusteredSharedVolume]  <>  [-Igroup]  <String>  [-InitiatorInfo]  <HostInitiatorInfo>  [-PortSet]  <String>  [-AutopickMountPoint]  <>  [-PartitionStyle]  <PartitionStyle>  [-ResourceGroup]  <String>  [-Thin]  <>  [-AllocationUnitSize]  <String>  [-RawDeviceMapping]  <>  [-Datastore]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Provisions dedicated disks, shared disks and clustered shared volumes on a LUN.
Name Description Required? Pipeline Input Default Value
Path
Specifies the drive letter or mount point: D:, D:\Mount
false
true (ByPropertyName)
Size
Specifies size of the new Windows disk you are provisioning.Supported units: G, T, K, M
true
LunPath
Specifies your LUN path in the following format: /vol/volx/lunx
true
StorageSystem
Specifies the target virtual storage machine you want to use for provisioning.
true
FileSystemLabel
Specifies the label you want to attach to your new Windows volume.
false
SharedDisk
Indicates whether you need to provision your Windows disk as a shared disk.
false
Indicates whether you will provision your Windows disk as a Clustered Shared Volume.
false
Igroup
Specifies the igroup you want to use for mapping the LUN. If not specified, SnapCenter Plug-in for Mcrsoft Windows automatically manages the igroup for mapping the LUN.
false
InitiatorInfo
Specifies the initiators you want to add to your Igroup.
false
PortSet
Specifies the portset you want to use for binding your Igroup. If yourIgroup is already bound to a different portset, specifying this parameter unbinds your Igroup and then binds it to the portset specified here.
false
AutopickMountPoint
Specifies that the mount point for the new LUN is assigned automatically.
false
PartitionStyle
Indicates whether you want to use GPT or MBR partition style.
false
ResourceGroup
Specifies a Cluster Resource Group for your shared Windows disk.
false
Thin
Indicates whether you want the LUN to be thin provisioned.
false
false
AllocationUnitSize
Specifies the custom NTFS allocation unit size. Possible values are: 4 KB, 8 KB, 16 KB, 24 KB, 32 KB, and 64 KB. The minimum allocation size is 4 KB, and the maximum is 64 KB. The default value is 4 KB.
false
RawDeviceMapping
Indicates whether the LUN is raw device mapping for VMWare.
false
Datastore
Specifies the Name of the datastore.
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies your target host.
false
Example 1: Provisioning a dedicated Windows disk
 PS C:\> new-sdstorage -StorageSystem  172.17.165.31 -path V: -LunPath /vol/santest/b09 -size 1G -InitiatorInfo @{Host="R505143C1AAV1.HNK2.COM"; Initiators="iqn.1991-05.com.microsoft:r505143c1aav1.hnk2.com"}
This example syntax creates a new dedicated Windows disk.
Example 2: Provisioning a shared Windows disk
 PS C:\> new-sdstorage -StorageSystem  172.17.165.31 -path V: -LunPath /vol/santest/b09 -size 1G -SharedDisk  -Igroup Windows2012_igroup
In this example syntax, you provision a shared disk in "Available storage" resource group.
Example 3: Provisioning a shared Windows disk in an alternate resource group
 PS C:\> new-sdstorage -StorageSystem  172.17.165.31 -path V: -LunPath /vol/santest/b09 -size 1G -SharedDisk -ResourceGroup prod  -Igroup SqlAG_igroup
In this example syntax, you provision a shared disk in prod resource group.
Example 4: Provisioning a new Cluster shared volume
 PS C:\> new-sdstorage -StorageSystem  172.17.165.31 -LunPath /vol/santest/b09 -size 1G  -ClusteredSharedVolume -Igroup Windows2012_igroup
In this example syntax, you provision a clustered shared volume.
Example 5: Provisioning a RDM disk with other options:(Datastore, FileSystemLabel, filesystemlablename)
 PS new-sdstorage -storagesystem autof7f8_vsvr1 -path K:\ -LunPath /vol/C227030162240_1_MDML_Log_Vol/Lun1 -size 3G -igroup C227030162240_1 -Thin -RawDeviceMapping -Datastore C227030162240_1VMFS_DS -FileSystemLabel filesystemlablename -PartitionStyle GPT
In this example syntax, you provision a RDM disk.
				TotalSizeInGB   : 3.00287246704102 GB
UsedSpaceInGB   : 3.00287246704102 GB
FileSystemIdentifier: autof7f8_vsvr1:/vol/C227030162240_1_MDML_Log_Vol/Lun1
FileSystemType  : ntfs
MountedFromSnapshot : False
TotalSize   : 3224309760
UsedSpace   : 3224309760
BlockSize   : 4096
Clustered   : False
Expandable  : True
OwnerNode   : False
MountOptions:
MountPaths  : {K:\}
parents :
Message :
ClusterAttributes   :
BootFileSystem  : False
BootFileSystemSpecified : False
bIsPathOnCSV: False
bIsPathOnCSVSpecified   : True
CSVReparsePointPath :
Example 6: Provisioning a RDM disk
 New-SdStorage -LunPath /vol/Vol_VM180_FC/L2 -Size 1GB -StorageSystem 10.225.21.111 -Igroup Sab_FC_ESX -Path M: -RawDeviceMapping
				TotalSizeInGB   : 1.00351095199585 GB
UsedSpaceInGB   : 1.00351095199585 GB
FileSystemIdentifier: sce_svm_1:/vol/Vol_VM180_FC/L2
TotalSize   : 1077511680
UsedSpace   : 1077511680
BlockSize   : 4096
Clustered   : False
Expandable  : True
OwnerNode   : False
MountOptions:
MountPaths  : {M:\}
parents :
Message :
ClusterAttributes   :
bIsPathOnCSV: False
Example 7: Provisioning a RDM/Windows disk with InitiatorInformation
 $initiatorlist = New-Object Collections.Generic.List[string]
			$initiatorlist.Add("10:00:00:90:fa:a6:32:63")
			$hostName = "Bay8-21264"
			$initiatorInfo = New-Object SMCoreContracts.HostInitiatorInfo -ArgumentList $hostName, $initiatorlist
			New-SdStorage -LunPath /vol/Abhi_FCOE_VOl1/L5 -Size 1GB -StorageSystem vs_21264 -Igroup ig_21264 -Path U:\ -InitiatorInfo $initiatorInfo
FileSystemIdentifier: vs_21264:/vol/Abhi_FCOE_VOl1/L5
BlockSize   : 4096
Clustered   : False
Expandable  : True
OwnerNode   : False
MountOptions:
MountPaths  : {U:\}
parents :
Message :
ClusterAttributes   :
bIsPathOnCSV: False
