SnapCenter 4.7 cmdlets
New-SmMultifactorAuthenticationMetadata
To create the metadata required to setup the MFA for SnapCenter in a specified location.
Syntax
New-SmMultifactorAuthenticationMetadata [-Path]  <>
Detailed Description
To create the metadata required to setup MFA for SnapCenter in the specified location.
Name Description Required? Pipeline Input Default Value
Path
Create SnapCenter MFA metadata at the specified path.
false
false
Example 1: Create SnapCenter MFA metadata at default location
This example syntax creates SnapCenter MFA metadata at default location.
SnapCenter MFA Metadata: SnapCenterMFAMetadata.xml successfully generated at: c:\ProgramData\NetApp\SnapCenter\Package Repository
Example 2: Create SnapCenter MFA metadata at specified location
 New-SmMultifactorAuthenticationMetadata -Path C:\SC_metadata
This example syntax creates SnapCenter MFA metadata at specified location.
SnapCenter MFA Metadata: SnapCenterMFAMetadata.xml successfully generated at: C:\SC_metadata
